Page 1 of 2
Osam Ignition switch key falls out, how to repair.
Posted: Sat May 10, 2014 2:52 pm
by Willie the pimp
Hi guys,
Got a Gp with an original Osam or Grabor ignition switch with the original key, keys mint no wear but it just falls out, I would like to try and repair this, any idea how to do it, it works fine in every other way but key won't hold in place.
I did take one of these to bits back in the 90's but it was quite a challenge and I had a job removing the alloy surround from the black plastic middle section, any advise would be much appreciated.
Cheers Ian.
Re: Osam Ignition switch key falls out, how to repair.
Posted: Sat May 10, 2014 4:13 pm
by jazzyb
Get intouch with jem booth to sort it m8
Posted: Sat May 10, 2014 4:50 pm
by rosscla
+1 get Jem to look at it
Posted: Sat May 10, 2014 6:07 pm
by Willie the pimp
Yeah I thought as much, I'll give him a try then, just fancied ago myself but probably best to leave to him.
Posted: Sat May 10, 2014 6:18 pm
by bristolmod
why not have a go- then send Jem the bits!
Posted: Sat May 10, 2014 9:03 pm
by Eddie15b
you can do it if you have a donar switch to play with but it must be an exact copy of your own
in the wires coming out of the back of the bakalite rear plate
basically the alloy housing needs to be machined down in a lathe to release the bakalite backplate
i think this is what jem does
not having a lathe then if you have a donar switch unit you can break up the bakalite in one
and the alloy housing in the other and then you can strip clean and reassemble the parts to make
one quality new/old ignition switch
the key falling out is usually down to a thin wire that holds in the latch springs which breaks or
jumps out of location and this means that the latches dont hold the key in position when in the switch
its a particularly fidely job but it can be done
the grabor switches are the most easy to rebuild
but the osam switches are an absolute bassa to reassemble
and best left to jem to use his expertese to rebuild
i can also confirm that having rebuilt a few for my own scooters
his prices are cheap for the amount of time involved
hope this helps
Posted: Sun May 11, 2014 1:06 am
by victor
jazzyb wrote:Get intouch with jem booth to sort it m8
I spent £60 with Jem and they still continued to fall out...
Posted: Sun May 11, 2014 1:36 pm
by dave wheeler
as with the others try jem but attach your key to a lanyard and put it round your handlebars
Posted: Mon May 12, 2014 12:16 pm
by Knowledge
I use a retractable yo-yo like this:
http://www.ebay.co.uk/itm/Black-Premier ... 3cd24548e3
This way, when the key falls out, it doesn't flap-about on the end of a bit of string, and retracts out of the way. Mine is clipped onto my brake reservoir.
In fact, having the key held on a retractable reel keeps a side-ways pressure on the key, and helps keep the key in the lock. An odd bi-product of using the retractable lanyard.
Posted: Mon May 12, 2014 2:09 pm
by victor
I gave up trying to restore mine and will get a remade one from beedspeed; they have one that comes with steering and toolbox lock all sharing the same key
For less than 40
