What jet sizes for standard SIL GP200??
Posted: Sat May 10, 2014 12:06 pm
Hi all,
I’m running a standard SIL GP200 with standard Jetex 22mm carb/filter (but airbox drilled), AF Clubman exhaust, factory ‘stage 4 tuned’ barrel (is it really?) and I’ve matched the barrel to inlet manifold, and exhaust manifold and barrel matched to the copper gasket.
I use Rockoil at 4% and super unleaded (97 ron).
It’s a common set up I think so there must be someone out there with lots of miles on the clock who can advise on what jets I should be running? Or at least to within two sizes of the jets??
I’m running very rich at moment because I’m concerned about seizing
What are you running on yours?
Thanks in advance and best regards,
Eric.
Eric.
