61,9 HP Vespa smalframe with rotax cylinder
Posted: Thu May 08, 2014 9:00 pm
New Setting, 61,9 HP !!!
The setting from january was untouched and we got only
59,2 Hp yesterday on the same dyno out of the engine. We know that there is clima correction software, but we also know that in the wintertime everybody is getting the highest results !
So the 59,2 HP was yesterday the maximum- timing of the ignition, carburator everything was testet.
Than we changed to our new carburator. 44mm XY Type (it will be a secret actually, if the carburator works perfect, we will inform the type an price)
Here you see the result, the carburator ist actually not correct adjusted, we need more time !
https://www.facebook...gwellen?fref=nf
https://www.facebook...&type=2
