Pictures of your PM Volante disc fitted
Posted: Wed May 07, 2014 7:29 pm
by steveg
Can anyone post some pics of a PM Volante single anti dive disc fitted? I want to have a look at hydraulic hose and speedo cable routing. Cheers
http://www.lambrettainnovation.co.uk/sh ... -dive.html
Re: Pictures of your PM Volante disc fitted
Posted: Thu May 08, 2014 4:09 pm
by steveg
I know it's a very specific request, but can anyone help? Cheers
Posted: Thu May 08, 2014 6:12 pm
by wack 63
Fitted one a fortnight ago and we routed the brake hose like a reverse pull cable with a 20 degree banjo on the caliper, allow enough hose to enable the wheel to be removed. We did away with the speedo drive as using a SIP speedo although a mate fitted his on the hub side and fitted a speedo cable bracket on the link pivot bolt on the left fork. If the speedo drive is facing the wrong way you need to remove the brass cap in a vice then remove the worm and drift the brass tube out then rebuild the opposite way.
Posted: Thu May 08, 2014 8:32 pm
by jonashford
You've seen mine Steve?? I don't use the speedo but I've routed the hose the same way as the speedo cable goes on a std hub. I got lee chambers to make me a hose to my requirements
Posted: Thu May 08, 2014 11:12 pm
by carlos fandango
Here you go steve, this has been converted to run tubeless , this is an old pic if you need one from a different angle let me know
Posted: Fri May 09, 2014 6:52 pm
by steveg
Thanks for that Russ.
Jon I have seen yours, but I never take much notice until I actually need something
I'm not going to be using a cable speedo either and was thinking of using that routing for the hose.
Wack, any tips for fitting or bleeding?
