Clutch operating cam fitting
Posted: Sat May 03, 2014 3:48 pm
by Sam_C
Ok...probably a dumb question but... on an SX type clutch, which way should the clutch operating cam ( the bit that pushes on the thimble) be fitted? Looking from above, should the "finger" of the cam point towards the left or the right?
Cheers! Sam
Re: Clutch operating cam fitting
Posted: Sat May 03, 2014 9:41 pm
by rosscla
The convex side should face the thimble on the pressure plate
Posted: Sat May 03, 2014 11:26 pm
by coaster
rosscla wrote:The convex side should face the thimble on the pressure plate
I'm not sure if it's possible to get it wrong but the finger points to the left, it's obvious if you think about it, the clutch arm is pulled ion a clockwise direction when you pull the lever in.
Posted: Sat May 03, 2014 11:39 pm
by rosscla
coaster wrote:rosscla wrote:The convex side should face the thimble on the pressure plate
Sorry for any confusion, got muddled between convex and concave.
The picture here -
http://www.scooterrestorations.com/lamb ... tch-chain/
Shows the correct orientation.
Posted: Sun May 04, 2014 1:17 pm
by Sam_C
Thanks gents. It is possible to fit it either way. I once got it wrong on a GP clutch and it slipped like a b***. Unfortunately, it was so long ago I forgot which way was correct
Posted: Tue May 13, 2014 10:38 am
by itwillrunproperly
the curved part should face towards the clutch thimble not the flatish part..... I had the same prob about what way it should go, it looks like an upside down comma or a number 6 <- this is how I think it should be
confused you should be
so the flat part rests against the crankcase
