Newfren Clutch Plates
Posted: Wed Apr 30, 2014 10:48 pm
Anyone had any problems with Newfren clutch plates?
Had one at the weekend only done a few miles and it started to drag badly, tried adjusting the cable still the same, striped it down and the plates are burnt, checked the clearance and it's just over 1mm, when built it was just under 2mm. Plates were soaked for about a week (maybe longer), everything moving smoothly, 2 mm clearance at the lever.
Then tonight on a mates GP that's just been rebuilt, only been rode up a track a few time just to check gears, clutch etc, all of a sudden clutch starts to drag badly
Both using Newfren plates, I've used loads of sets of both standard and 5 plate without problem
