Diamond pistons: Yes or No?
Posted: Tue Apr 29, 2014 11:37 pm
by vegansydney
I need a standard 62.0mm piston for a TV175. What are my options for a
quality 'non-conversion' piston?
Scooter Restorations list an
Indian made Diamond piston that is 2 thin ring (1.5mm) type and from what I can ascertain, including gudgeon pin, are only 283 grams, comparatively a 2 fat ringed Diamond (including gudgeon) weighs 315 grams and similar 2 'fat ring' Mahle weighs 300 grams. Thoughts on the thin ringed Diamond? Yes? No?
If no, other suggestions? NOS Borgo? NOS Asso? Casa 3 ring (manufacturer unknown)? Others?
Re: Diamond pistons: Yes or No?
Posted: Wed Apr 30, 2014 5:13 pm
by dave wheeler
I HAD to use a diamond 62.8 as it was the only option, i would not recomend them at all, they are built like a tank, weigh a ton, rings appear to be made of cheese,and you must have at least 3.5 thou clearance if you want real quality and are in it for the long term them mb pistons are hard to beat, but so is the price!that said rimini borgo ones arent far behind, as long as my piston gets me to switzerland and back ill be well chuffed and suprised!
Posted: Wed Apr 30, 2014 6:56 pm
by vegansydney
Many thanks! Unfortunately the MB only go as small as 64mm. Are NOS Borgo pistons that good? Anyone have other recommendations? Seems like more options are available for 'conversion' pistons than standard TV pistons.
Posted: Wed Apr 30, 2014 9:53 pm
by dave wheeler
yup, but changing the crank means losing the tv smoothness and lots of extra cost
Posted: Wed Apr 30, 2014 10:17 pm
by bristolmod
always used their Mahle in my TV with no probs whatsoever.
Posted: Thu May 01, 2014 7:55 am
by ArKaTxU
Posted: Thu May 01, 2014 9:24 pm
by vegansydney
http://www.scooterotica.co/forum/viewto ... 3&p=143823
Thanks for that link. The thin ring Diamond piston is the one I'm curious about, so that is most helpful--thanks! Also, as noted above, keeping the TV crank (translation: custom GP tapered 58/116) is in my best interest and finally I don't want to rebore, as cylinder is on it's original size and otherwise immaculate.
Posted: Thu May 01, 2014 9:30 pm
by TS1-200
I had the same reservations, but they were the only piston I could get in the size I needed, put one in an SX200 engine and so far seems ok, engine feels quite smooth, I did have it bored with a 4 - 4.5 thou clearance. mines going to Switzerland.
Posted: Thu May 01, 2014 10:08 pm
by lambrusco
I've got a 67 one in my LI, done about 2000 mile with no probs so far.... touch wood.
