wandering timing
Posted: Thu Apr 24, 2014 10:54 pm
guys. any help appreciated.
Long story but I have problems with my timing moving all over the place.
It all started when I went to fit an M Tech. Now the whole idea is that they advance and retard your timing and this is seen as a good thing.
At the time I had just hold a piston within 500 miles of a rebuild after loosing compression due to stuck rings, turned out I had lost plating on my muggy so it was redone.
Looked at cooling the thing down with the M tech but at the time of fitting I noticed my old stator had 2 lugs broken ( they had been weakened by me opening up the slots so own goal.)
Fitted my spare and went ahead trying the M Tech. After 3 or 4 months I was not happy so removed it. went back to a static 17 DBTDC.
It was a bitch starting and found that I was getting a lot of spit back into the carb rubber, if I removed the rubber it started no problem.
went down the carb route swapping the 22mm for a 26mm Jetex but it was the same. In the end went to check my timing and on a medium revs it was spot on 17 degrees but on tickover it went to 5 to 10 degrees at at that point I got the spitback.
Fitted the old broken stator and the timing was more stable so got a new BGM version 3. Timing still OK on revs but on tickover its wanders now away from 17 degrees back to 25 ish. replaced the CDI with one from a mate and that changes the firing point by 10 degrees but still wanders by around 8 to 10 degrees.
tried 2 different timing lights and they show the same result.
The M Tech is disconnected.
Unfortunately I added the extra wire to use the BGM as DC so Im stuck with it.
Any ideas as to what can make the timing jump around. been thinking about pickup heights but I'm getting big differences by just changing the CDI. at the moment the only connections are the red white and green.
I have a BGM CDI coming but Im running out of ideas
Any comments appreciated
