What spark plug to use for WOT?
ericthered
Main scooter: GP 200 SIL
Hi all,
Just got the jetting sorted on my GP200 and would like to know what spark plug I should be using if going on a decnt run out and using wide open throttle a lot? Not motorway as such but decent A roads.
Its a SIL GP200 with AF clubman, standard indian stage 4 barrel (but with inlet and exhaust matched to barrel and internal casting faults removed but not polished), 22mm Jetex running 130 main and 48 pilot, and drilled airbox.
Been using an NGK B7ES.
Should I be using B8ES for long runs??
Thanks and regards,
Eric.
Rally220
Main scooter: Lambretta S2 TS1 240
B7ES for round town, B9ES for long runs.
ericthered
Thanks Rally220, I'll give that a go.
Burnside
Main scooter: Lambretta TV200
Stick a B8ES in, it'll be fine for round town and long runs, shouldn't need a B9 for a standard setup
ericthered
Thanks for that.
I called AF Rayspeed to order one and they said they prefer Champion as Ray thought he lost up to 500rpm (at max rpm)running an NGK.
Anyway, getting an N4 and an N3 (N3 same as B8ES I think), going to use the N3 for all round use and long runs and keep the N4 for back up.
Best regards,
Eric.
ericthered wrote:Thanks for that.
Best regards,
Eric.
Really :?: never heard that before :lol:
speedy
There were folk who said that NGK worked best in Vespas and Champion work best in Lammies. I have no idea if this theory is true or not,however, I do use this system myself, I don't know why, but I do :D . I also used to like Nippondensu ZU plugs, but they are harder to locate. Think it's just personal choice really.Cheers,Speedy.
    Users browsing this forum: Semrush [Bot] and 9 guests
