What spark plug to use for WOT?
Posted: Tue Apr 22, 2014 6:52 pm
by ericthered
Hi all,
Just got the jetting sorted on my GP200 and would like to know what spark plug I should be using if going on a decnt run out and using wide open throttle a lot? Not motorway as such but decent A roads.
Its a SIL GP200 with AF clubman, standard indian stage 4 barrel (but with inlet and exhaust matched to barrel and internal casting faults removed but not polished), 22mm Jetex running 130 main and 48 pilot, and drilled airbox.
Been using an NGK B7ES.
Should I be using B8ES for long runs??
Thanks and regards,
Eric.
Re: What spark plug to use for WOT?
Posted: Tue Apr 22, 2014 7:06 pm
by Rally220
B7ES for round town, B9ES for long runs.
Posted: Tue Apr 22, 2014 11:47 pm
by ericthered
Thanks Rally220, I'll give that a go.
Posted: Thu Apr 24, 2014 7:51 am
by Burnside
Stick a B8ES in, it'll be fine for round town and long runs, shouldn't need a B9 for a standard setup
Posted: Thu Apr 24, 2014 12:59 pm
by ericthered
Thanks for that.
I called AF Rayspeed to order one and they said they prefer Champion as Ray thought he lost up to 500rpm (at max rpm)running an NGK.
Anyway, getting an N4 and an N3 (N3 same as B8ES I think), going to use the N3 for all round use and long runs and keep the N4 for back up.
Best regards,
Eric.
Posted: Fri Apr 25, 2014 8:38 am
by shocky
ericthered wrote:Thanks for that.
Best regards,
Eric.
Really :?: never heard that before :lol:
Posted: Fri Apr 25, 2014 10:59 am
by speedy
There were folk who said that NGK worked best in Vespas and Champion work best in Lammies. I have no idea if this theory is true or not,however, I do use this system myself, I don't know why, but I do :D . I also used to like Nippondensu ZU plugs, but they are harder to locate. Think it's just personal choice really.Cheers,Speedy.
