Px200 or p200e
wrecklessrobbie
Main scooter: li150
Its probably been asked before. I cannot find the answer.
Which is best the px200 or p200e engine, in terms of aftermarket cylinder, gearing and tuning etc.
Robbie
Juan
For myself the EFL motor without question. Only downside from the earlier motor is the internal rather than external hub seal.
gaz_powell
I use a combination of both
early casings as I don't want autolube - as said it has the external rear hub seal but I use the EFL gearbox parts (better cruciform set up) and a COSA clutch.
other than the g/b parts fundamentally everything else is the same/interchangeable - crank, top end etc
Gaz
wrecklessrobbie
Main scooter: li150
OK,
Thank you for the replies.
Robbie
