is my thermostat f@@ked?
Posted: Thu Apr 17, 2014 11:10 pm
was driving in heavy slow motorway traffic, GT125 with Malossi 210 kit cut out but restarted, then backfired alot and cut out, started again..... pulled into hard shoulder and saw that 2 rubber pipes had melted at the nipples - the 2 brass nipples in the photo
not the tube that carries the coolant
what would cause it to overheat so much that the pipes melted? is the thermostat goosed or is there another reason??
was driving in heavy slow motorway traffic, GT125 with Malossi 210 kit cut out but restarted, then backfired alot and cut out..... pulled in and saw that 2 rubber pipes had melted at the nipples
