Page 1 of 2
lightening a 6volt ducati flywheel
Posted: Sun Apr 13, 2014 2:54 am
by scooterslag
Yeah know its not the best solution but I've a SX200 thin taper crank in good condition which I want to use in a very mild 175 conversion (standard pipe, 22mm delly carb etc) Now I know the best logic would be to buy a GP crank for such a thing but sadly I can't afford to ( not made of money plus other commitments dictate) the LI/SX crank is prone to shearing off the odd taper but I've noticed a few peeps getting around this problem by lightening the flywheel. Now does anyone know the standard weight of a ally Ducati 6 volt SX flywheel, what would be a sensible minimum weight to reduce it by which isn't going to effect the tick over etc too much and who could do this job well? cheers Paul
Re: lightening a 6volt ducati flywheel
Posted: Sun Apr 13, 2014 3:50 am
by bristolmod
before you do anything, ask yourself how many "thin taper" cranks have actually broken.
I've had scooters since 1968 and the only flywheel/ taper problem I've ever had was a flywheel on a TV200 which split along its taper due to excessive tightening. (air gun in a garage!!)
I know Innocenti revamped the flywheel set up on the GP range to counteract breakages, but with a mild 175 tune, I really don't think its going to be a problem in your case.
Also, beware of replacing good original Innocenti stuff for poor replacement stuff.......theres enough horror stories about poorly fitting parts to last a lifetime.
Lightening may be a good idea but you may sacrifice a smooth tick over due to lack of inertia.
Posted: Sun Apr 13, 2014 4:09 am
by scooterslag
Thanks for the information and your experience Chris, I've done quite a bit of research on here and the LCGB forum about li/sx crankshafts shearing at the taper. it seems about a 50/50 split to if the crank is suitable/unsuitable for the task- I was thinking about lightening the flywheel just to sit on the fence
will probably run the crank and flywheel as the factory intended.cheers again Paul
Posted: Sun Apr 13, 2014 4:13 am
by bristolmod
no problem Paul.
FWIW I ran a TV175 S3 with a Muggy kit on original crank AND 6v points- never missed a beat and no problems.
If you do get the F/W lightened, please advise how it runs- may consider it myself.
Now- time for bedy byes!!
C
Posted: Sun Apr 13, 2014 7:46 am
by warts
If the crank has had a hard life then maybe it could be a problem.
Back in the day, I never heard of it happening - maybe to real racers, but not us street boys.
In '67 my SX had a 70mm bore and tune by A Francis in Watford. Only downside was the huge fuel consumption from the Wal Phillips "fuel injector".
Posted: Sun Apr 13, 2014 9:38 am
by wack 63
Easiest would be to get the brass centered Ducati flywheel and remove the fan then fit a nylon one, that's what we did in the 80's
Posted: Sun Apr 13, 2014 10:18 am
by Muppet
dont lighten the cast ducati dont fit a self destruct brass jobby
Posted: Sun Apr 13, 2014 11:36 am
by scooterslag
Muppet wrote:dont lighten the cast ducati dont fit a self destruct brass jobby
Ok so the ally and brass flywheels are a bit of a no-no, what would you recommend ?
Posted: Sun Apr 13, 2014 11:43 am
by scooterslag
warts wrote:If the crank has had a hard life then maybe it could be a problem.
The cranks no shiny NOS item, but had Al Diablo check it out a couple of years ago and he said it was fine, its looking like I'm probably going to run it as is. I've ran a smallframe vespa engine with a small taper (not the thicker PKXL taper) and a lightened flywheel and that helped with the problem of sheared tapers. I was hoping to do similar with the SX crank but not want to remove too much material that it either weakens the flywheel or causes erratic tick-over problems. What's the difference in weight between the standard ally Ducati 6 volt flywheel and the electronic flywheel (using a sx.li cam) ? a lot of people seem to use them on their engines and didn't know if there was a weight difference between them? Paul
Posted: Sun Apr 13, 2014 4:37 pm
by johnny LIS150
there is a comprehensive article about flywheels and lightening in one of Mr B's articles . It gives weights and types of flywheel swopping around etc and replacing the fins with plastic etc .
Most damage on scoots and bikes is caused by over-tightening and heavyhandidness with aluminium .Some people just have no 'feel' with materials
