series 1 low rider
Posted: Thu Apr 10, 2014 12:58 pm
by tea5ive
right, i cant wait any longer for my for my current series 1's paint job to be finished before i start the next series 1. so i have made a start on the panel work and have knocked it back to shape and now its just about ready for paint , i will be having ago at the paint myself this time so i can only blame myself if its s**t or takes longer than the first series 1.
i fancy a hot rod theme i.e white with flames on the side panels and was also wanting to get the scooter to sit lower thinking two to three inches . has anyone done this and where do i need to start cutting
. cheers simon
Re: series 1 low rider
Posted: Thu Apr 10, 2014 5:53 pm
by coaster
[quote="tea5ive"]...i fancy a hot rod theme i.e white with flames on the side panels and was also wanting to get the scooter to sit lower thinking two to three inches/quote]
Not planning on riding it round any corners then
Posted: Thu Apr 10, 2014 7:19 pm
by bolzenanker
I was admiring a series 1 low rider in Brighton last year, I'll try and find the pics for you. Oh, and the owner/builder...Harry Barlow.
Loads to consider when doing it I remember him saying. Plus very little kickstart travel. So so cool though.
Posted: Thu Apr 10, 2014 7:31 pm
by bolzenanker
Here you go, is this the kinda thing?
Posted: Fri Apr 11, 2014 1:47 pm
by tea5ive
[quote="coaster"][quote="tea5ive"]...i fancy a hot rod theme i.e white with flames on the side panels and was also wanting to get the scooter to sit lower thinking two to three inches/quote]
[/quote
the motor and exhaust etc wont be any lower its the frame/ body work that needs to be lowered ....... i think
Posted: Fri Apr 11, 2014 1:59 pm
by tea5ive
bolzenanker wrote:Here you go, is this the kinda thing?
yes this looks great, sits just right. was thinking about movinig the rear shock mount up a bit or cutting a bit of fthe rear damper spring or both and then shortening the front fork legs and notchtching the kickstart panel for kick start clearance ??
Posted: Fri Apr 11, 2014 2:30 pm
by coaster
tea5ive wrote:coaster wrote:tea5ive wrote:...i fancy a hot rod theme i.e white with flames on the side panels and was also wanting to get the scooter to sit lower thinking two to three inches/quote]
[/quote
I just had visions of the legshields grounding but looking at the scoot in the picture, it doesn't look too bad
Posted: Fri Apr 11, 2014 2:36 pm
by ArmandTanzarian
Air suspension. Any ride height you like from slammed to off-roader
