ts1 and Mikuni 35 tmx
Posted: Thu Apr 03, 2014 7:20 am
by Boo
Hi all, any one changed a mikuni 35mm tmx on a ts1 to another carb and was it any better?
Engine Spec
TS1 230
35 tmx 20 pilot 57 needle 2nd clip from top 320 main no 6 slide mixture 1.5 turns out
nk road pipe
set up on dyno
recently fitted a kytronic smart booste( 26 static) no7 position thought this may help at low revs
Always spluttered around quarter throttle (still did after dyno session)
think the only solution now is to change carb tried everything else
Cheers in advance
Re: ts1 and Mikuni 35 tmx
Posted: Thu Apr 03, 2014 10:22 am
by corrado
Lots using them here ...... http://scooterotica.org/forum/viewtopic.php?f=9&t=14
Though 1st few all seem to have 58 needles.
Posted: Thu Apr 03, 2014 10:46 am
by jonashford
Try going up 1 size same clip position on the needle, then if it improves try next size up on the pilot jet, it might clean it up
Posted: Thu Apr 03, 2014 5:34 pm
by Boo
jonashford wrote:Try going up 1 size same clip position on the needle, then if it improves try next size up on the pilot jet, it might clean it up
Thanks for the replies.
jonashford do you mean going up one clip position on same needle to the top position?
Posted: Thu Apr 03, 2014 6:19 pm
by jonashford
no try a 56 needle on the 2nd clip
Posted: Thu Apr 03, 2014 6:58 pm
by drunkmunkey6969
jonashford wrote:no try a 56 needle on the 2nd clip
56 is richer than the 57 he is running.
Posted: Thu Apr 03, 2014 7:05 pm
by Rally220
30mm PHBH on my TS1 225, plenty carb enough for it. I've heard of lots of people going 'down' from 34 or 35 mm carbs to 30mm!
Posted: Thu Apr 03, 2014 7:51 pm
by Boo
Think that will make splutter worse m8
Posted: Thu Apr 03, 2014 8:09 pm
by jonashford
ok no problem
Posted: Fri Apr 04, 2014 6:07 pm
by Boo
Update
Replaced 57 needle with 58 same clip position (2nd from top) cleaned up loads a lot better to ride now.
:D
