New Gran Turismo Crankshafts
Posted: Wed Apr 02, 2014 10:23 pm
The first prototype Gran Turismo crank shafts are being assembled for testing. It has taken over 18 months to optimise the design of the webs and stuffers to produce this full circle, balanced crank (optimum balance on 58/110 with 350LC piston). During this time specific software has been used to calculate balance masses, CoG's and mass off sets. To cross check information, OEM and existing cranks have been modelled and balance information compared.
The initial 10pcs prototype specification will be 110 rod, 58 stroke based on CNC machined Indian GP webs.
Production will be based around 58 and 60 stroke GP webs (Indian and Italian) with three rods (110, 115 and 125) and two pins 22mm dia and a 22/24 off-set pin which offers 6 variants of crank configuration all 40.5mm wide.
Why is this crank project different?
The crank is production orientated, specific fixtures for machining and assembly have been made, for production stuffers will be injection moulded. This is all done to optimise cost and return value for money.
It's fully CAD designed to achieve precision balance and assembly
It's a genuine full circle, low drag design
It's the lightest crank available (lighter than OEM)
How long? Well, there is still some way to go in testing first, I'd say about 4-5 months before production if all goes well.
How much? Well, depending on the response from dealers the specification will come in three levels, the targets are: 1. lowest cost £130 (donor Indian GP webs), Mid £170(new Indian Webs), Top £220(new Italian webs). The use of 125mm rods and off-set pins will be slightly more.
