New 200 SIL stripdown ... Grit and sand...!!
Posted: Sat May 23, 2009 7:25 pm
Taking an SIL engine apart its the one I posted the pics of the stator repair and 12 volt rewire....
I thought after all the scare stories I had heard, I would do a complete strip and rebuild... This is a new factory item... Took the barrel off first.... the head studs and nuts must have been tightened by Superman... Tight is an understatement... But the barrel is quite tidy for an Indian stage 4.. I will fit an Asso after its been honed to size...
With the barrel removed, I then gauged the bore to piston clearance... Using a micrometer and a pin gauge then checking again with feeler gauges... its got less than 2 thou of an inch clearance... Thats too tight IMO...
The Cylinderhead has a poor gasket face on one edge ( badly cast )... I will try to post a photo ... The crank is also missing a small piece of Crank web, again... photo needed...But I dont think it will effect the running.... The small end bearing was covered in grease and grit...... Yam 110 rod to be fitted...
When I took the side case off, having drained the oil which was very gritty... the inside of the case was also covered in some sort of grit or sand... I will take the gearbox and axle out and replace all the bearings so they dont fail later....The chain also had about 20mm of up and down free play... fitting an IWIS
The good news is the drive bearing is a 6305 C3, seven ball bearing Item, but the bad news is its full of grit... The mag bearing is an NU 2205 E C3... luckily this is clean and grit free...
I Can see a need to check these engines prior to using them but prehaps this is just a bad one out of the batch...
... Anyone else had this with a new SIL..??
