TV175 EXHAUST REPLACEMENT
Posted: Tue Apr 01, 2014 10:02 pm
by camel
Hi....ive purchased a std tv175 series 3, apart from electronic ignition its as it was when it left the factory,the exhaust is a little tatty and ive had a quick look at some replacement exhausts,i don't want a clubman I want to keep it std....ive seen one std exhaust at £180
..what are my choices available
I feel a fish out of water with this as ive only ever ran expansions
cheers in advance
Re: TV175 EXHAUST REPLACEMENT
Posted: Tue Apr 01, 2014 10:26 pm
by Doom Patrol
You could try a SIL GP exhaust from Scooter Restorations. Don't know what the quality is like, as I've never knowingly seen one up close, but they'd be pattern exhausts and at a good price.
Posted: Tue Apr 01, 2014 11:11 pm
by lambro
Tatty as in a blast and powder coat??
Or a replacement??
Tutto are the best for sound and quality, but dear, although cheaper than a good expansion.
If not rotten and deffo original and not weighing 30 kilo, blast and coat for me
Posted: Tue Apr 01, 2014 11:17 pm
by camel
Its not blowing so you may well have a point there Lambro
Posted: Wed Apr 02, 2014 4:18 pm
by Doom Patrol
lambro wrote:Tatty as in a blast and powder coat??
Or a replacement??
You could do that of course, but you could probably buy a new SIL one for less. Or even look on e.Bay.
Posted: Wed Apr 02, 2014 6:37 pm
by DigDug
Doom Patrol wrote:lambro wrote:Tatty as in a blast and powder coat??
Or a replacement??
Fit is the problem - my TV3 Innocenti is rotten underneath. I have a SIL box on currently and the downpipe isn't the same as the "real" one. Result is the tinware doesn't fit properly with it on. I'm not mutilating it to make it fit.
It will be a Tutto for me - shame as the top is in good nick.
Posted: Sat Apr 05, 2014 5:37 am
by Grumpy225
Hot tank, blast off the rust and have it welded. If you find a good welder you can have it patched up and look good again. Has to be cheaper than a replacement although the TUTTO is a great factory exhaust.
Posted: Sat Apr 05, 2014 5:56 am
by DigDug
Grumpy225 wrote:Hot tank, blast off the rust and have it welded. If you find a good welder you can have it patched up and look good again. Has to be cheaper than a replacement although the TUTTO is a great factory exhaust.
Good welders don't come cheap on this side of the pond....
