Page 1 of 2
li to gp clutch
Posted: Mon Mar 31, 2014 8:59 pm
by tea5ive
what do I need to convert from li to gp type clutch centre, I am sure I have done this in the past but brain fade has set in and cant remember what is needed, cheers simon
Re: li to gp clutch
Posted: Mon Mar 31, 2014 9:19 pm
by dapper
You need a GP brass thimble, a GP clutch pressure plate, and. GP side casing as it differs from an Li casing.
Re: li to gp clutch
Posted: Mon Mar 31, 2014 9:43 pm
by tea5ive
brain fade has now passed, I think all that's required is an li pressure plate with the thimble :lol: as I have a clutch with a gp type pressure plate :lol:
Re: li to gp clutch
Posted: Mon Mar 31, 2014 9:53 pm
by dapper
No, you numpty. You asked to change from Li to GP clutch. The side casing has an additional recess to allow for the GP brass thimble. The Li side casing doesn't have this. Or am I being the numpty :?: :oops: :lol:
li to gp clutch
Posted: Mon Mar 31, 2014 10:10 pm
by drunkmunkey6969
To change from Li to GP you will need a new GP chain-case and brass plunger. You'll also need to change your pressure plate to GP. You'll also need to tap and drill holes in your new GP case for the Li kickstart ramp.
Re: li to gp clutch
Posted: Mon Mar 31, 2014 10:16 pm
by tea5ive
1, I have an li type side case .
2, I have a new complete clutch, with the nipple-less pressure plate.
all I have to do is swap the pressure plate for an li type ( with nipple)
no need for side case swap
Re: li to gp clutch
Posted: Mon Mar 31, 2014 10:49 pm
by drunkmunkey6969
If you say so....
Re: li to gp clutch
Posted: Mon Mar 31, 2014 10:59 pm
by dapper
I tried to tell him. :roll:
Re: li to gp clutch
Posted: Mon Mar 31, 2014 11:04 pm
by tea5ive
yes I do,
this is what I have http://www.scooterrestorations.com/lamb ... ch-flange/ and should have this http://www.scooterrestorations.com/lamb ... ch-flange/
and yes I thought it was known as the pressure plate :oops:
Re: li to gp clutch
Posted: Mon Mar 31, 2014 11:12 pm
by drunkmunkey6969
Your original post asked how to convert from an Li pressure plate to a GP pressure plate. So that's the question I answered.
Now you are saying the opposite.....that you have a GP pressure plate???
