varitronic difference between ultimate & normal
Posted: Mon Mar 31, 2014 1:46 pm
by shureimage
Hi, As subject says, whats the difference between ultimate & normal varitronic. I've read its strengthened (how ?) is anything else done ?
Cheers Dom.
Re: varitronic difference between ultimate & normal
Posted: Mon Mar 31, 2014 7:50 pm
by jason frost
The rivets are welded
Posted: Mon Mar 31, 2014 7:58 pm
by Speed Demon
The flywheel and boss are also welded with a special rod because they are made from different metals. IMHO this is highly advisable on Varitronics used on anything revvy or that produces much over 22hp.
Posted: Mon Mar 31, 2014 8:28 pm
by jason frost
Speed Demon wrote:The flywheel and boss are also welded with a special rod because they are made from different metals. IMHO this is highly advisable on Varitronics used on anything revvy or that produces much over 22hp.
Last one I had, only the rivets looked like they had a tig torch near them.
Posted: Mon Mar 31, 2014 8:33 pm
by Speed Demon
Did you take the fan off Jase - one's we've had have also had beads of weld from flywheel to boss on 4 points around the flywheel but it's hidden by the fan. Could be different on the new type though.
Posted: Mon Mar 31, 2014 8:40 pm
by jason frost
Will have a look, need to set the timing on it so will check, thanks for letting me know
Posted: Mon Mar 31, 2014 11:16 pm
by soosh
Anyone had to weld a Ducati flywheel from an old AF kit?
Posted: Mon Mar 31, 2014 11:57 pm
by shureimage
OK cool, cheers for that, so basically if I get my flywheel welded it becomes the ultimate, nice one cheers again Dom.
