Cosa clutch wear
lambro
Just after opinions on this wear:
Shite picture, but it is angled/worn in towards the centre.
Possible causes and symptoms if any ideas gratefully recieved.
Shaun.
Jack221
Main scooter: PX221
Pictures hard to see but at a guess the nut was probably not done up tight enough and or fat thrust washer missing :roll:
Vespa est ieiunas, quia semper operaturi
fastfrog
pump washer was set?
Size matters!
lambro
Chers guys,
Not sure on the cause, when I stripped it, the clutch washer/oil drive was in 6 pieces, and the clutch was worn like this.
I didn't know which would have caused what first, and if it was something people had seen before.
Clutch was tight and oil was ok.
Hopefully was just a faulty washer, or some animal well overtightened the clutch in the past :?
