Experimenting with Front Suspension
Posted: Wed Mar 26, 2014 12:59 pm
by Tommy Boy
I have a place local to me who can make me suspension springs in any strength, length and colour so I want to experiment with a front end set up that does away with the need for internal springs. I have some adjustable suspension units that I think will work but wanted to pick the engineering brains on here before I pull them apart.
Can anyone advise the spring loading I should be aiming for for a Lambretta front end?
Also can someone confirm the length of standard dampers from eye to eye.
Thanks
Tommy
Re: Experimenting with Front Suspension
Posted: Wed Mar 26, 2014 3:51 pm
by tonydevon
my outboard shockers are 80lb springs, I would personally like a little softer, but thats just me
Posted: Wed Mar 26, 2014 4:04 pm
by shocky
If you use the standard front shock mounting points these will not be strong enough to support external shockers
Posted: Wed Mar 26, 2014 4:35 pm
by Tommy Boy
Thanks Tony that gives me something to work with.
Cheers Shocky yes will be removing the original damper brackets and getting a stronger fixing welded on
