LTH disc brake - where do the washers & spacers fit??
Posted: Mon Mar 24, 2014 8:23 pm
by soullad
Just received an LTH front disc brake with anti - dive .... in parts ... there are 2 x 1mm washers and 2 spacers, approx 8mm, anyone know where they go? The anti-dive / caliper parts are all fine and built up
Also, I take it there are no seals used as the bearings have internal seals? So do you still need to fit the hub side original outer spacer / top hat?
An exploded diagram would be a nice?
Posted: Tue Mar 25, 2014 8:47 am
by soulsurfer
Re: LTH disc brake - where do the washers & spacers fit??
Posted: Tue Mar 25, 2014 8:51 pm
by Angry Bloke
Hi Ian - when I fitted mine I had a similar query .
I've just dug out my notes and this is the order I have written down
From the left hand side
- Dome Nut
- washer
- fork link
- flat nut
- Top hat
- oil seal
- circlip
- bearing
- spacer
- bearing
- oil seal
- spacer
- shim washer
At the speedo drive housing
- circlip ( modified )
- bearing x2
- shim x2
- flat nut
- fork link
- washer
- dome nut
Hope this helps - if you are over this weekend I will copy all my notes and drawings for you ( or post if you PM your address)
Posted: Tue Mar 25, 2014 10:07 pm
by soullad
Cheers Peachy, is this for the LTH item?
The hub side has no seperate seals, the bearings have the integral seals?
I also need the caliper and reservoir banjo bolt sizes, pitch / thread.
usual Lambretta fettling resumed
Posted: Tue Mar 25, 2014 10:36 pm
by Angry Bloke
^ yes it's LTH from a couple of years ago - I assume they have changed it to integral seals now but the rest should be current .
Sorry can't remember the thread pitch as I changed it for a SIP Caliper
Posted: Wed Mar 26, 2014 12:36 pm
by corrado
Nissin ones are 10mm x 1.25 pitch, though I think LTH use non-nissin from memory. Caution as banjos also come in 10 x 1.00.
Venhill ones come with cheese head and allen key fitting which I found useful on the master cylinder with limited access for a spanner. Sorry Ian I don't carry any Venhill spares but I've got the std bolt type in Black.
Caution also as the std banjo bolts can be too long with certain after market hoses with thinner "eyes".
