Vespa PX/Rally
Posted: Sun Mar 23, 2014 11:37 pm
by kevspeed
Ok,ive been asked the question,but I don't know the answer,so ill leave it to you guys to verify...................Can you fit PE/PX crankshaft and bearings/seals into a set of Rally 200 cases?
Re: Vespa PX/Rally
Posted: Mon Mar 24, 2014 7:54 am
by OzOAP
No.
P Range crank will fit Rally casings with Rally bearings/seals.
Re: Vespa PX/Rally
Posted: Mon Mar 24, 2014 8:14 am
by mick1
I thought some of the later/last Rallys' were compatible with the P range ? The early Rallys' had a self extracting flywheel and a large flywheel side bearing, the later Rallys' (mine was a 77') had the smaller bearing and required the extractor tool the same as a P range..........but i may be wrong
