px 200 squish
Posted: Sun Mar 23, 2014 10:23 pm
by nam65
Hi all
anybody know what squish a standard 200 should be I keep reading
squish should be around 1.2 -1.5 not sure if this is correct and how
you can reduce it if its greater than that without reworking the head.
any info appreciated
Re: px 200 squish
Posted: Mon Mar 24, 2014 8:01 pm
by GLscoot
Don't know the specs, but if its greater than what you expect, I can't see any other way than getting the head skimmed.
gary
Re: px 200 squish
Posted: Mon Mar 24, 2014 8:45 pm
by santacama
The standard 200 does not have a squish head system, the head does not have the proper angle to match the piston head. It is possible to raise the compression cutting the head but it will never work with 1 mm distance piston to head because the squish angle, the squish band and the proper combustion dome are missing.
Re: px 200 squish
Posted: Tue Mar 25, 2014 4:08 am
by Jack221
The standard 200 design works fine as it is since the 70's but put in a 60mm crank without any packer or changing anything else. Will feel a bit more torquey and rev a little higher.
Re: px 200 squish
Posted: Tue Mar 25, 2014 9:58 am
by santacama
The standard 200 design is archaic.
Re: px 200 squish
Posted: Tue Mar 25, 2014 3:22 pm
by nam65
cheers all info is much appreciated
Re: px 200 squish
Posted: Tue Mar 25, 2014 7:35 pm
by Jack221
santacama wrote:The standard 200 design is archaic.
Yeah, what I said! It's a dinosaur but it works fine
