Page 1 of 3
1964 LIS150 Round or square junction box ?
Posted: Fri Mar 21, 2014 12:51 am
by johnny LIS150
The junction box on my Italian imported 1964 LIS150 was missing and the 4x magneto wires were joined to the loom with an electrical junction strip.
There is the remains of rectangular black junction box cap pushed up the loom which would suggest that is was a series 2 junction box fitted originally rather than the series 3 type but there are also bits of Vespa scoots on the bike so who knows ?
Has anyone got a early pre 65 Italian import Li150 special could look at theirs please and tell me what type it is
Re: 1964 LIS150 Round or square junction box ?
Posted: Fri Mar 21, 2014 2:01 am
by wayne cudine
Mine's the same year/model as yours and the junction box on the left hand was a round one if that helps.
Posted: Fri Mar 21, 2014 5:34 am
by bristolmod
Italian market (i.e. non battery models) were equiped witth a small rectangular junction box as standard.
Battery models had the larger Rectifier/ Junction box.
Not sure to what the round junction boxes were fitted but they seem to be the only ones available now
Posted: Fri Mar 21, 2014 11:52 am
by johnny LIS150
Thank you Wayne and Chris.
Wayne perhaps yours is a UK model ?
Chris I'd forgotten that yours is the same as mine ...
So the rectangular cover is probably the original I guess. I'll scout around for an original junction box but in the meantime I guess the electrical connectors will suffice.
Chris could I be a right pita and ask if you could post an image of your ignition key for me please ? Mine came with no keys whatsoever so I'll need to find the key pattern to start with and probably file my own keys or alternatively I guess I could buy 3x new locks and swop the barrels but that would be kinda expensive .
Johnny
Posted: Fri Mar 21, 2014 12:34 pm
by bristolmod
there should be a number on all of the locks/ ignition switches.
There is a guy called Jem Booth on here who will supply keys ready cut.
Very good bloke and quite reasonable.
BTW what are the first 5 digits of your frame ane engine numbers? May be very close to mine
Posted: Fri Mar 21, 2014 1:59 pm
by roli-olo
In my shed i have part of the junction box(I.e. the part with the windings,fuse etc).this was attached to a 1964 lis150 frame I once had.if you don,t find a complete unit you can have this for£10.00plus Post&packing.I can,t do photos on here but can email if required.Roli.
Posted: Fri Mar 21, 2014 2:38 pm
by bristolmod
roli-olo wrote:In my shed i have part of the junction box(I.e. the part with the windings,fuse etc).this was attached to a 1964 lis150 frame I once had.if you don,t find a complete unit you can have this for£10.00plus Post&packing.I can,t do photos on here but can email if required.Roli.
thats the "junction/ rectifier" box which was fitted to machines with a battery.
He's looking for the small rectangular junction box for non battery models.
Posted: Fri Mar 21, 2014 7:28 pm
by roli-olo
Oops sorry.
Posted: Fri Mar 21, 2014 8:34 pm
by johnny LIS150
bristolmod wrote:there should be a number on all of the locks/ ignition switches.
thanks Chris I'll contact Jem asap .
My frame and engine numbers are
150LIS23231#
150LI 7387#
how close are they to yours ?
Posted: Fri Mar 21, 2014 8:36 pm
by johnny LIS150
roli-olo wrote:Oops sorry.
thank you Roli thats a very kind offer
The part I'm looking for I believe looks like this ... I'm sure that Chris will be able to confirm if I am right or not.
