Autolube
Posted: Tue Mar 18, 2014 9:57 pm
by Hammerite
I,ve just realised the that the PX engine I,ve bought in bits and about to rebuild is an autolube one. The hole in the casing to the carb has been filled with mastic. Whats the best way to do this properly as I dont want the autolube .Wouldn,t have thought a big dollop of mastic is good enough in the long run. Can I remove the small gear wheel thats the drive for the autolube from behind the clutch
Rich
Re: Autolube
Posted: Tue Mar 18, 2014 10:16 pm
by OzOAP
You need to keep the gear (or fit spacer from non autolube) as it 'shims' the clutch to engage with the primary.
I thread the hole in the casing and seal with grub screw.
Re: Autolube
Posted: Tue Mar 18, 2014 10:17 pm
by soulboy
mine is done with silicone had no probs
Re: Autolube
Posted: Wed Mar 19, 2014 5:13 am
by Jack221
Put chemical metal in mine. I ain't never going back!
Re: Autolube
Posted: Wed Mar 19, 2014 6:55 am
by Hammerite
Thanks for your suggestions fellas
Rich
Re: Autolube
Posted: Wed Mar 19, 2014 7:56 am
by Train Driver
I love autolube and just wish someone would do a quality conversion for the lambretta
Re: Autolube
Posted: Wed Mar 19, 2014 5:34 pm
by GLscoot
You can buy a plug for the axle and it comes with a needle bearing for the small hole, costs about £6.
Re: Autolube
Posted: Wed Mar 19, 2014 5:37 pm
by ducksta
sip blanking plate in mine interfearance fit yes you get to use the hammer
Re: Autolube
Posted: Thu Mar 20, 2014 9:34 am
by joeythescooterboy
Go to a plumbers merchant and get a 10mm endfeed stop end....... tap it in and Bob's your Aunty. Costs about 10 bob.
