Page 1 of 2
scooter towing question
Posted: Mon Mar 17, 2014 3:04 am
by johnny LIS150
its late and I'm tired and this is probably a daft question but how feasible is it to tow a lambretta behind a vehicle with just the front wheel off the ground ?
I was thinking of using something like this for short distance recovery http://www.ebay.co.uk/itm/221393815802? ... EBIDX%3AIT
Re: scooter towing question
Posted: Mon Mar 17, 2014 9:14 am
by Andy W
I don't know about a Lammbretta but I have seen motorbikes being towed with their front wheel in a cradle (can't see ebay from my work account) and the back wheel rolling, so I would assume that you could. I had thought of doing that as well, I will have a look at the link when I get home.
Posted: Mon Mar 17, 2014 9:24 am
by slangen
Hopefully it does not slip in to 1:st doing 60.
Posted: Mon Mar 17, 2014 10:57 am
by coaster
I can't quite see how that attaches to the tow bar, it must locate solidly somehow :? Good idea though but I wouldn't want to use it for much more than local recoveries and at low speeds personally.
Posted: Mon Mar 17, 2014 11:32 am
by Speed Demon
Like this you mean?
Just be prepared that the back of the towed scooter leans over quite a lot as you turn tightly so you need decent ground clearance.
Posted: Mon Mar 17, 2014 11:38 am
by johnny LIS150
Andy W wrote:I don't know about a Lammbretta but I have seen motorbikes being towed with their front wheel in a cradle (can't see ebay from my work account) and the back wheel rolling, so I would assume that you could. I had thought of doing that as well, I will have a look at the link when I get home.
the reason I asked was because I thought that scoot gearboxes and transmissions operate differently than motorcycles ? Someone told me that the scoot gearbox would be turning the whole time it was towed ?
I haven't really looked at the scooter transmission yet so I don't know exactly how the drive is transmitted to the rear wheel and what happens when the scoot rear wheel is turned in neutral. :oops:
Posted: Mon Mar 17, 2014 11:44 am
by joespeed
if the gearbox was seized or other then you could fit the front wheel in and tie the steering up!
Posted: Mon Mar 17, 2014 12:15 pm
by Speed Demon
No the gears will all be still, only the shaft will turn inside the loose cogs. As long as there is oil in the gearbox it won't be a problem, unless for some reson it slips into gear!
Posted: Mon Mar 17, 2014 1:04 pm
by warts
My Dad towed his scrambler (as they were called then) to meetings. Maybe up to 30 miles away. Only thing I remember him complaining about was how quick his knobblies wore.
He removed the chain, dropped the front wheel, slipping the axle though a bracket on the bumper, all nice and secure.
Scooter gearbox is gonna churn all the time. Iffy if there may be bits floating around in there?
Posted: Mon Mar 17, 2014 1:58 pm
by johnny LIS150
excellent ! :)
It will only be used to recover my scoot or bike in the event of a puncture or breakdown unless I'm miles from home and then I'll call the AA .
For long distance I intend to buy or make a tow hitch carrier to sling it on the back of the campervan. :D
Its a lovely simple design but at £100 far too expensive for what it is so I'll make my own for about £20 and I ordered the tubing last night.
