Duelling banjos
Posted: Sat Mar 15, 2014 4:28 pm
by lammydave
ok... setting up a scootrs disk brake with nissin caliper
replaced the hose with a goodridge...
all bolted up, but hose leaks at the banjo on both ends...
using original supplied bolts...
then I noticed that the banjos are different thickness...
so, I guess I need a shorter banjo bolt??
if so, what size and where from, please...
ta
Re: Duelling banjos
Posted: Sat Mar 15, 2014 6:13 pm
by Grumpy225
Not to sound daft but you have the copper sealing washers in place?
Typically I've found is there isn't much variation in the banjo bolt lengths. I am by no means a hydroloc expert but they are somewhat standardized.
Re: Duelling banjos
Posted: Sat Mar 15, 2014 6:52 pm
by coaster
Grumpy225 wrote:Not to sound daft but you have the copper sealing washers in place?
There are differences in the bolt lengths, had the same problem myself, I thing there is a guy on here (could be LCGB) called Chiggy? that does them.
Re: Duelling banjos
Posted: Sun Mar 16, 2014 8:13 am
by lammydave
Well... hopefully a solution is in hand...
I'd fitted one of these brakes before and it gave me no issues at all..
Now I remember that I bought an uprated hose, which came with new banjo bolts and washers...
Thanks to Boreham on this site, I will soon be in possession of said bolts and washers... so watch this space!!
And a massive "Thank you" to Boreham... you are a gent!
