fitting a fuel tap
Posted: Wed Mar 05, 2014 2:14 pm
Ok your first dumb question of the day and your starter for 10 , no conferring.
how do you fit a replacement fuel tap ? Waiting for my sticky to arrive so no manual at present.
The existing fuel tap on my LIS150 is fubar and leaking all over the place. I saw a high flow tap on ebay and though Mmmmmm just the job !
Do you wind the tap into the nut first then wind the whole tap onto the tank spigot or do you fit the nut on the tank first then wind the tap into the nut ?
What if the tap doesn't line up correctly do you stick some ptfe on the spigot ? I thought I'd ask first in case there are some tips that would make the job easier. I read on one thread its a good idea to cut the filter down so that the reserve doesn't start too early.
