Tuning definitions please if you'd be so kind
Posted: Tue Mar 04, 2014 11:18 am
by speedy
Just out of interest,as I have no knowledge whatsoever regards a couple of terminologies that you hear quite often. Firstly,regards the Avanti tt3...What does MWO port layout/design mean? Secondly the one I hear a lot now and through the years is Boyessen ports,layout and reeds. Sorry if I sound a bit naieve,but I genuinely have never known what they mean
cheers,Speedy.
Re: Tuning definitions please if you'd be so kind
Posted: Wed Mar 05, 2014 10:24 am
by speedy
Anyone?.....Please!
Posted: Wed Mar 05, 2014 11:08 am
by drunkmunkey6969
I forget exactly, but the MWO is something like Moss Wrap Over port, it refers to a type of feeder port on the piston port TT3 kit which feeds from the main transfers to a port on the back wall of the cylinder.
Boyessen was the surname i believe of the chap who pioneered the research of feeder ports which directly connected the inlet area of a reed valve engine and the main transfers. He also developed other items like dual stage reeds (standard reeds were a single layer, his were a dual layer).
Posted: Wed Mar 05, 2014 11:12 am
by DigDug
There is some blurb on the Supertune websight.
Posted: Wed Mar 05, 2014 8:06 pm
by speedy
Aha thank you both,that's much appreciated. It was just one 'or two as it goes,terms that I just didn't understand. I know know what it means when I next see either in print,cheers,Speedy.
