Programable ignition
Posted: Mon Mar 03, 2014 11:13 pm
by sydduckett
not really up on these so some basic sort of questions really. the other posts are already way ahead of me.. :D
do you need a specific stator set up like a varitronic?
Appears there are ones that have one curve only that can't be changed and others that have a number of curves. how do you change from one pre programmed curve to another, is there a physical switch or is it a case of plugging a laptop in each time you want to change curves?
Thanks
Sef
Re: Programable ignition
Posted: Mon Mar 03, 2014 11:40 pm
by eden
some have a switch and if using one of the off the shelf ones you use a normal stator
