px rear hub oil seals
Posted: Sat Feb 22, 2014 2:52 pm
by Eibar
got p200e with what appears to be later px casings as hub oil seal is internal.
Question: Is it safe to ditch external dust seal and use the external type oil seal to allow use of an unshielded bearing and aid ease of changing seals in the future. I have 30mm od hub centre and matching 29.89mm id external oilseal (tora). cant see any drain off holes in the casing (as i;ve read people mentioning these needing sealingoff with epoxy .
Re: px rear hub oil seals
Posted: Tue Apr 01, 2014 8:21 pm
by byron
was wondering this too..?
removed the internals from a broken early [external oil seal] casing
ok to fit everything into some LML casings ?
