Page 1 of 3
Painting Engine Casings
Posted: Wed Feb 19, 2014 7:06 pm
by GLscoot
I am planning to paint my engine casings, using the correct engine/heat paint. I can either get it in spray or a tin and paint it on. If I get the paintbrush stuff how easy is it to get a good finish, or something that reassembles a good finish.
Re: Painting Engine Casings
Posted: Wed Feb 19, 2014 7:13 pm
by jason frost
Powder coat it, job done
Posted: Wed Feb 19, 2014 8:10 pm
by coaster
GLscoot wrote:I am planning to paint my engine casings, using the correct engine/heat paint. I can either get it in spray or a tin and paint it on. If I get the paintbrush stuff how easy is it to get a good finish, or something that reassembles a good finish.
'll let you know, I just bought a can of brush on satin black engine enamel as the coating I spayed on 3 years ago was chipping off on a number of places. Hopefully I'll get a chance to give it a go this weekend. The spray finish was very good when I first applied it, powder coat would be the best way but quite expensive and difficult to get off if you change your mind in the future. It would also require completely stripped cases.
Posted: Wed Feb 19, 2014 8:15 pm
by ducksta
powder coat everytime
Posted: Wed Feb 19, 2014 9:05 pm
by GLscoot
ducksta wrote:powder coat everytime
Thats what I thought and was put of doing it, now I have done the porting, bearings and seals. How difficult is it to get the engine bolt mount out and shock mount. Im using brand new casings.
Posted: Wed Feb 19, 2014 9:08 pm
by ducksta
hard lol if you done that work already then paint it
Posted: Wed Feb 19, 2014 9:36 pm
by Muttley McLadd
edit.. can't delete.
Posted: Wed Feb 19, 2014 10:23 pm
by GLscoot
I think i will paint them, start with the brush stuff and if looks shiit I will use the spray stuff for the final coat. Got a set of knackered casings I can experiment on first. I take it Nitromorse will be able to remove the heat paint.
Posted: Wed Feb 19, 2014 10:40 pm
by sp1v
Just dropped casings & mag flange off for powder incl blasting, £70 all in. Thought that was quite reasonable.
Posted: Thu Feb 20, 2014 8:24 am
by drunkmunkey6969
sp1v wrote:Just dropped casings & mag flange off for powder incl blasting, £70 all in. Thought that was quite reasonable.
Where's that at?
