Page 1 of 2
best pipe for ts1
Posted: Fri Feb 14, 2014 12:58 pm
by roadrunnerian
hi,
is the new nk race pipe for the ts1 better than my franspeed race, i.m after using it for quick acceleration anyone any thoughts thanks :)
Re: best pipe for ts1
Posted: Fri Feb 14, 2014 4:41 pm
by Boreham
The Franspeed race is (in my humble opinion) the best exhaust for the TS huge power and revs, i have tried a few and this exceeded everything else.
Posted: Fri Feb 14, 2014 4:59 pm
by 10 inch Terror
I've tried both and the NK wins for me. A very good bit cheaper and a great fit (as is the Franspeed) In my opinion the NK gives the best bang for your buck of any race pipe.
Posted: Fri Feb 14, 2014 5:34 pm
by Adam_Winstone
All depends on what you want the bike to ride like; touring, hooligan or somewhere in between.
Posted: Fri Feb 14, 2014 6:03 pm
by Andy Pickering
All I know is the franspeed race turned my avanti into a fking hooligan off the line ;-)
Sent from my GT-I9300 using Tapatalk
Posted: Fri Feb 14, 2014 7:03 pm
by Eibar
are these findings based on plug and play ts1;s or torquey tunes. for the record my nk rally does most things on a reeded tuned rapido 225 barrel, but won't rev stupidly high.
Posted: Sat Feb 15, 2014 6:11 pm
by roadrunnerian
thanks for your replies, Adam i just need the scooter to be a hooligan m8 :D
Posted: Sat Feb 15, 2014 7:03 pm
by Andy Pickering
Franny race then
Posted: Sat Feb 15, 2014 7:56 pm
by Adam_Winstone
In which case I don't know about the NK but your current Fran Race should do the job nicely.
Posted: Sat Feb 15, 2014 10:01 pm
by drunkmunkey6969
NK race is dogshit and should be banned, it has no bottom end or midrange. Peak RPM and BHP is great, but the rest is missing. Franspeed race will give same peak BHP figure but at lower RPM.....with more torque and mid range.
However.....NK RALLY pipe has a right mid range kick to it and can pull gearing well, with a decent over-rev too. Peak numbers less than hooligan pipes, thus less boasting rights, but a better ride with right gearing.
