Page 1 of 4
LED rear light conversions
Posted: Fri Feb 14, 2014 12:16 pm
by tonydevon
has anyone ever tried just putting an LED bulb in the unit?
or is the best solution just to get something like the BGM board and be done with it
I like the idea of the BGM unit as its thin and should give even light, is it very bright?
Re: LED rear light conversions
Posted: Fri Feb 14, 2014 12:19 pm
by jedan71
I have scootrs rear led panel, easy to wire, have to fettle GP housing to mount board, but good clear and bright light, and hardly any flicker on idle with a.c.system. highly recommend to get one.
Sent from my GT-I9505 using Tapatalk
Posted: Fri Feb 14, 2014 12:27 pm
by tonydevon
ok thanks, I hadnt heard of that one, hence why I wanted to ask and see what else was out there
I got full 12vDC system with big battery so thats not a problem, just wanted something bright and reliable
Posted: Fri Feb 14, 2014 12:29 pm
by tonydevon
ooooh found it on the scootrs site, and clear lens, now thats cool
Posted: Fri Feb 14, 2014 12:50 pm
by ArmandTanzarian
I just bought a cheap light unit from ebay and took the guts out. Fitted inside the housing a treat.
http://www.ebay.co.uk/itm/UNIVERSAL-3-F ... 2ec812e34c
Posted: Fri Feb 14, 2014 1:10 pm
by tonydevon
thanks I had looked at them but thought it was too big, hadnt thought of removing the lens and trimming the case etc
Posted: Fri Feb 14, 2014 7:39 pm
by Timbo
The BGM ones are great, just stick them on with silicone....
Posted: Fri Feb 14, 2014 7:53 pm
by immylam
BGM board is very good, my rear light was dull to the point of dangerous, put the board in and it works very well and bright, feel safe from behind, now if only I could do something to get my headlight brighter than a firefly.
Posted: Fri Feb 14, 2014 8:26 pm
by soulsurfer
immylam wrote:BGM board is very good, put the board in and it works very well and bright, feel safe from behind.
Agreed
immylam wrote:now, if only I could do something to get my headlight brighter than a firefly.
You can, go DC ;)
Posted: Sat Feb 15, 2014 1:27 am
by Minority
Another thumbs up for the BGM one from me, was pretty bright on ac, even better now on dc.
