li light switch.... wassell
Posted: Mon Feb 10, 2014 9:52 pm
by joeswoonara
just converted an li s3 to full dc using a MB simplified loom (just brown black and green at the headset ) and also added a MB ignition switch any one have a wiring diagram or any pointers as to how to wire it up (lights ) in conjunction with an LI light switch i have used the white to earth the horn so thats ok .....it`s just the rest of the spaghetti
Re: li light switch.... wassell
Posted: Mon Feb 10, 2014 11:59 pm
by Monty
No easy answer to this one. Effectively you need to wire your key switch to do your lights as say an SX or TV would be wired, sidelights and headlights all working from the switch with dip, full beam and horn left on the switch. I would follow an SX.TV drawing. but most of the switches available have odd ball colour coding so its time to get your meter out and work out what is what. remember a simplified loom only has 1 feed, a normal loom has 2 so your brown and purple need to be connected at the headset or only half the stuff will work.
Have a look at Ricspeeds post with drawings by Mark? on the 1st page of this
http://scooterotica.org/forum/viewtopic ... 32&t=14360
It covers it very well ignoring the spot lights
