wassel conversion
gp200ts1
Main scooter: lambretta series 2
I converted my gp to a full 12v dc set up last year but recently the battery ran down and I realised that without the battery connected that the lights were very dim, any idea what might be wrong with the wiring set up or the conversion to cause this?
ArmandTanzarian
It sounds like you aren't generating enough power. With everything in place you should get a minimum of 13V across the battery. Any less than that and it won't charge properly.
firekdp
Charge the battery and refit it. There probably nothing wrong with the system, the reg/rec isn't designed to operate without a battery in circuit.
Monty
Check any in line fuse on the battery.
