wassel conversion
Posted: Sun Feb 02, 2014 10:57 am
by gp200ts1
I converted my gp to a full 12v dc set up last year but recently the battery ran down and I realised that without the battery connected that the lights were very dim, any idea what might be wrong with the wiring set up or the conversion to cause this?
Re: wassel conversion
Posted: Sun Feb 02, 2014 11:05 am
by ArmandTanzarian
It sounds like you aren't generating enough power. With everything in place you should get a minimum of 13V across the battery. Any less than that and it won't charge properly.
Posted: Sun Feb 02, 2014 12:42 pm
by firekdp
Charge the battery and refit it. There probably nothing wrong with the system, the reg/rec isn't designed to operate without a battery in circuit.
Posted: Sun Feb 02, 2014 6:07 pm
by Monty
Check any in line fuse on the battery.
