sip caliper
Posted: Sat Jan 25, 2014 7:30 pm
by sjc
iv got a pm tuning front disc brake which uses the grimeca vespa caliper..would i be able to replace this with a sip caliper? cheers steve
Re: sip caliper
Posted: Sat Jan 25, 2014 7:48 pm
by soulsurfer
Well it's a straight swap on a Vespa ;-)
It's a bit thicker than the Grimeca, so if you have clearance it should be okay. If you post a pic of yours I might be able to tell, unless someone's already done this swap...
Re: sip caliper
Posted: Sat Jan 25, 2014 9:59 pm
by martinr
sjc wrote:iv got a pm tuning front disc brake which uses the grimeca vespa caliper..would i be able to replace this with a sip caliper? cheers steve
what colour you after ive got a gold one for sale
Re: sip caliper
Posted: Sun Jan 26, 2014 12:45 pm
by wack 63
I fitted one to the PM hub with AF tubeless rims .Just a straight swap.
Re: sip caliper
Posted: Sun Jan 26, 2014 10:43 pm
by Muttley McLadd
You'll need a bigger m/c too, or you'll have a lot more lever travel.
Re: sip caliper
Posted: Mon Jan 27, 2014 8:54 am
by soulsurfer
Muttley McLadd wrote:You'll need a bigger m/c too, or you'll have a lot more lever travel.
I think it'll be fine, I ran one with a hidden master, I also ran the Stage6 4 pot radial caliper with the hidden master too, no issue whatsoever, in fact, it had a great feel ;)
