R1 Shock Vibration
Posted: Tue May 19, 2009 9:55 am
by soulsurfer
A mate called me yesterday to tell me he swapped his Hagon shock over to a R1 shock with 180lb spring only to find unbearable vibration at 5000rpm. When he swapped back to the Hagon, the vibration went. My first thought is to slacken the engine bolt but the Hagon seems ok. Anyone else experienced this?
Re: R1 Shock Vibration
Posted: Tue May 19, 2009 10:02 am
by Bufficus
Has he got too much pre-load and dodgy damping settings?
Mine works a treat but it take a bit of setting up to get it how I like it.
Posted: Tue May 19, 2009 10:07 am
by jason frost
could be the mounts in the damper
Posted: Tue May 19, 2009 10:29 am
by soulsurfer
jason frost wrote:could be the mounts in the damper
Do you mean the bushes Jason? If so they're the nylon type.
I'm not saying the shock is faulty, it was supplied by Chiggy, and I'm more than happy with mine supplied by Shocky, just curious really as it was offered to him to try someone who didn't like it and his mate that had tried a different one didn't like it either, I assume they must be set up wrong
Posted: Tue May 19, 2009 11:00 am
by JohnnyH
Check that it's not touching the rear mudguard.
I've seen a few that were and have caused vibrations like this.
Either space the shock away from the mudguard or bend the mudguard in slightly.
Posted: Tue May 19, 2009 12:37 pm
by jason frost
Yes never liked the idea of solid mounting them but they have been fitted to 100s so what do I know. :lol:
Posted: Tue May 19, 2009 12:45 pm
by soulsurfer
JohnnyH wrote:Check that it's not touching the rear mudguard.
Just checked and aparently it was. I've offers to let him try mine with spacers and set up properly.
Jason, I thought you were doing some sleeved bushes??
Posted: Tue May 19, 2009 4:45 pm
by shocky
mike do you have the setting up instructions if not here you go .......your mates a triator ;)
Posted: Tue May 19, 2009 9:09 pm
by soulsurfer
shocky wrote:mike do you have the setting up instructions if not here you go .......your mates a triator ;)
Got that thanks Steve. My mate hasn't bought one, he was lent one to try by someone else who didn't like it, that was from Chiggy ;) Don't worry, I'm loyal, he hasn't bought one yet :D
Posted: Wed May 20, 2009 3:05 pm
by jason frost
soulsurfer wrote: Jason, I thought you were doing some sleeved bushes??
I did but they worked out to much money next to the plasitc ones.
