sip speedo question
Posted: Mon Jan 20, 2014 4:53 pm
by roadrunnerian
Hi,
i have set up my speedo to the specs i require, will it work ok with out the adjustment button or do i need it to turn it on every time i start it up thanks
Re: sip speedo question
Posted: Mon Jan 20, 2014 5:30 pm
by Stampede
No, it works without the button - but you can“t switch through the modes without.
Posted: Mon Jan 20, 2014 7:15 pm
by Timbo
It's a challenge fitting the button. Don't think you can fit it between the head set top and bottom (unless they're a bad fit) as they act like a guillotine ..
.....so I've been told.....
Posted: Mon Jan 20, 2014 8:14 pm
by rosscla
I just threaded it thru the slot I cut for the hydraulic hose
Posted: Mon Jan 20, 2014 8:25 pm
by lambro
