Carb settings for polini kit
Posted: Sun Jan 19, 2014 12:30 pm
by KyleGosling
Hi guys, got a polini 180 kit with a 24mm carb, Venturi filter and polini exhaust . Jetting 3BE mixer, 118 main, 55/160 idle, 160 air corrector. Starts buts I can't seem to get it to tick over, do I start with the mixture screw at the back of the carb if so how many turns out would be a good place to start?
Thanks
Re: Carb settings for polini kit
Posted: Sun Jan 19, 2014 2:19 pm
by acko
For a start your main jet is way too small with that venturi kit thing.
Even without it i used to run a 125 main jet.
I'm sure it says go up at least 8 points with the venturi kit.
Posted: Sun Jan 19, 2014 2:20 pm
by acko
Forgot to say my casings were ported to match the kit but you must go up with the venturi kit.
Posted: Mon Jan 20, 2014 6:00 pm
by davemartin
Definitely go bigger with the Venturi, I'm running a 122 without, 55/160 3be mixer and 140 air corrector.
Maybe check the tickover screw as well as the mixture screw. If the mixture screw is slotted then 1 1/2 turns if not then 2 1/2. These are just starting points.
