best 200cc tune on a budget
Posted: Thu Jan 16, 2014 10:04 pm
by ducksta
standard vespa 200cc electric start model engine, got a mazz crank in it. whats the best kit/standard barral tune, for motorway cruising without busting the bank £500 budget
Re: best 200cc tune on a budget
Posted: Thu Jan 16, 2014 11:08 pm
by Muttley McLadd
That's quite a big budget. Couldn't you get a Polini top end and a SIP road for that?
Posted: Thu Jan 16, 2014 11:37 pm
by ducksta
so alloy polini kit sip road exhaust bit of porting?
Posted: Fri Jan 17, 2014 12:39 am
by drunkmunkey6969
ducksta wrote:so alloy polini kit sip road exhaust bit of porting?
Yes....I'd say so.
Posted: Fri Jan 17, 2014 1:24 am
by gaz_powell
stage 4 tune (HB or similar) and spend the rest in the pub !
A true long distance long life touring tune - like a P2 should have been built from the factory .......with a SIP Road
Posted: Fri Jan 17, 2014 5:28 am
by Jack221
£500 is way more than you need, if you know what you are doing! but it really all depends what Mazz crank you put in already. Was it a 57mm or 60mm? If it was a 60mm Mazz crank I can help you get quite a few more free bhp out of a standard barrel. If you have a 57mm crank then you might as well get to the Polini shop!
:D
Posted: Fri Jan 17, 2014 8:40 am
by mick1
Ducksta: give QMT a call, i'm sure they can help...you just pick what bits of chrome you want on it and leave the rest to QMT :mrgreen:
by ArmandTanzarian
gaz_powell wrote:stage 4 tune (HB or similar) and spend the rest in the pub !
Seconded.
But I'd also add a long stroke crank and possibly a T5 fourth gear.
TBH £500 wont go as far as you think. It's all very well spending a chunk of money on a kit, but what about everything around it? Unless that's in tip top condition, the extra power will kill it off quite quickly.
Posted: Fri Jan 17, 2014 6:21 pm
by ducksta
mick1 wrote:Ducksta: give QMT a call, i'm sure they can help...you just pick what bits of chrome you want on it and leave the rest to QMT :mrgreen:
so folks youve heard it from the horses mouth QMT are taking on tuning work just contact mick1 with all your requirments. ;)
Posted: Fri Jan 17, 2014 6:24 pm
by ducksta
the above post is a private joke folks.
