Page 1 of 2
Best clutch ?
Posted: Thu Jan 16, 2014 9:50 pm
by poppygun
What's the best clutch out there Reedspeed AF race or road LTH MB and so on . At the moment I have a MB deep crown wheel with 5 green plates done about 2000 miles on it but it's starting to slip at high speed so I think it's time for a upgrade so the question is which one . Any thoughts or recommendations will be greatly received Thanks Poppygun
Re: Best clutch ?
Posted: Thu Jan 16, 2014 9:53 pm
by tarmac tickler
APRILIA CONVERSION,, best by far
Re: Best clutch ?
Posted: Thu Jan 16, 2014 10:33 pm
by jonashford
af surflex clutch £440 IMO
Re: Best clutch ?
Posted: Thu Jan 16, 2014 11:05 pm
by Muttley McLadd
What engine/gearing are you running?
You've put better springs in, haven't you?
Re: Best clutch ?
Posted: Fri Jan 17, 2014 12:40 am
by drunkmunkey6969
If money no object....LTH 7 plate.
Re: Best clutch ?
Posted: Fri Jan 17, 2014 8:25 am
by 10 inch Terror
AF race, take the old one out, put the AF in and forget about it. The action takes a while to get used too, but once mastered, it's a great clutch.
Re: Best clutch ?
Posted: Fri Jan 17, 2014 9:06 am
by DigDug
drunkmunkey6969 wrote:If money no object....LTH 7 plate.
What he said...
Re: Best clutch ?
Posted: Fri Jan 17, 2014 2:35 pm
by corrado
poppygun wrote:What's the best clutch out there Reedspeed AF race or road LTH MB and so on . At the moment I have a MB deep crown wheel with 5 green plates done about 2000 miles on it but it's starting to slip at high speed so I think it's time for a upgrade so the question is which one . Any thoughts or recommendations will be greatly received Thanks Poppygun
Upgrade existing clutch with a Foxhat spider, MB pressure plate, 6 Red plates.
or ........ money no object LTH, fit and forget.
or ......... go mad and contact those nice Foxhat chaps and go up to 8 plates.
Re: Best clutch ?
Posted: Fri Jan 17, 2014 2:45 pm
by 10 inch Terror
It all depends on your engine spec. There's no need to spend more than £100 on anything under 20BHP in my opinion. You can get a Readspeed 5 plate kit for £50 and you can still use all your other standard clutch parts. I'd swap over the supplied springs for MB ones (personal preference) and you'll have a lovely light clutch for very little money. Add the cost of a new clutch cable, oil and chain case gasket and you'll have change from £100. Why over egg the pudding when there's no need to?
Re: Best clutch ?
Posted: Fri Jan 17, 2014 6:16 pm
by MAB
Rocho's clutches are great but NO longer available for a while and also the LTH 7 plate is a fantastic clutch would have to say the best on the market IMO.
