This issue comes up frequently. I haven't got time to list everything so thought I'd start it rolling with the first part then over to everyone else to add one part at a time.
Item, from where and cost. Working on the basis of the average untouched SIL GP200 engine being £1,000.
1. GP200 casing with silent blocks and end plate fitted from Scooter Restos £349.00
Re: New SIL engine or build from empty casing?
Posted: Fri Jan 10, 2014 2:23 pm
by DigDug
2.LTH clutch 400 euro's.
Posted: Fri Jan 10, 2014 2:40 pm
by soulsurfer
This is a list of parts required in alphabetical order. I can't remember where I got it from but it's in Excel format and quite comprehensive, so may have been Richard Taylor.
Lambretta engine parts for a rebuild
casing
brake arm
brake arm circlip
brake cam & shim
brake cam grease nipple
brake shoe circlips & plates
brake shoe pivot pins & washers
brake shoe spring
brake shoes
bumpstop
bumpstop washer
chain
chain guide nuts & washers
chain guide studs
chain guide, bottom
chain guide, top
clutch arm
clutch arm spring
clutch bellhousing
clutch circlip
clutch corks
clutch lever
clutch nut
clutch shaft
clutch shaft circlips x4
clutch shaft o ring
clutch shim
clutch spider
clutch springs
clutch steels
clutch tab washer
clutch thrust thimble / brass bush
clutch top plate
crankshaft
crownwheel
crownwheel bearings / bush
cylinder
cylinder cowling
cylinder head
cylinder head nut kit
cylinder studs
drive side bearing
drive side bearing plate screws
drive side seal
drive side seal plate
drive side washer
endplate
endplate bearing
endplate bearing circlip
endplate dowels
endplate nuts
endplate shim
endplate studs
endplate washers
engine bolt
engine mounts
engine studs 14 x M6x33
exhaust casing studs 2 x M8
exhaust cylinder studs M7
exhaust gasket
exhaust header pipe
exhaust nuts & washers
flywheel
flywheel cowling
flywheel dustcover
flywheel dustcover circlip
flywheel nut & washer
front sprocket
front sprocket bolt
front sprocket collar
front sprocket oil thrower washer
front sprocket sliding dog
front sprocket spring
gear cog loose 1st
gear cog loose 2nd
gear cog loose 3rd
gear cog loose 4th
gear selector balls
gear selector pin clips x2
gear selector pins x2
gear selector shaft
gear selector shaft bolt & washer
gear selector shaft bush
gear selector shaft o ring
gear selector spring
gear selector wishbone
group cluster
group cluster bearing outer track
group cluster needle bearing
group cluster shim
group cluster track shim
inlet gasket
inlet manifold
inlet nuts & washers
inlet studs
kickstart buffer
kickstart circlip & washer
kickstart inner bush
kickstart lever
kickstart outer bush
kickstart piston
kickstart piston pin
kickstart piston plate
kickstart piston spring
kickstart ramp
kickstart ramp bolts & washers
kickstart seal
kickstart shaft
kickstart spring
kickstart stop
layshaft
layshaft bearing bush
layshaft needle bearing
layshaft o ring
layshaft shim
mag housing
mag housing bearing spacer
mag housing circlip
mag housing gasket
mag housing grommet
mag housing inner seal
mag housing outer seal
mag housing stator wiring plates
mag housing stator wiring plates gasket
mag housing studs 3 x M6x25
mag side bearing
oil drain plug & fibre washer
oil filler cap & fibre washer
oil level plug & fibre washer
piston
piston pin
piston pin circlips
piston rings
rear bearing
rear bearing flange studs 4 x M6x21
rear bearing flange thick
rear bearing flange thin
rear bearing housing nuts & washers
rear bearing seal
rear hub & cone
rear hub nut & washer
rear hub nut lockwasher set
rear hub spacing washer
side casing
side casing dowels
side casing gasket
side casing nuts & washers
small end bearing
stator
stator bolts & washers x3
stator wiring clip
woodruff key
Posted: Fri Jan 10, 2014 2:44 pm
by hungdog
Rocco 6 plate clutch £200...
Posted: Fri Jan 10, 2014 3:06 pm
by Rich_T
I've been running these numbers myself. It is the unfortunate truth that if you do not have a very ready (and comprehensive) Aladin's cave of old parts (gear boxes bearings, clutches primary drives etc) then the cheapest option is to buy a compete Indian engine, strip off the parts you don't want and leave or modify the parts that are suitable. This even applies if you have to totally gut the engine.
Posted: Fri Jan 10, 2014 3:43 pm
by mick1
Another option (as just done by a mate) buy said 200 casings and buy a second-hand 125/150 engine and use the parts to help build a new motor. It is the smaller "cheap" items that make a build from scratch very expensive.
Posted: Fri Jan 10, 2014 4:49 pm
by rosscla
Posted: Fri Jan 10, 2014 5:47 pm
by corrado
It was more of a game really [a bit like the "pointless thread on song titles" ] with one part added per post to see who spotted the last missing bit of the jigsaw.
OK, who's going to fill in all the prices on Mike's list?
Posted: Fri Jan 10, 2014 5:59 pm
by slangen
mick1 wrote:Another option (as just done by a mate) buy said 200 casings and buy a second-hand 125/150 engine and use the parts to help build a new motor. It is the smaller "cheap" items that make a build from scratch very expensive.
This is the way to go, but I tend to strip and throw away 175 casings as I like that gearing better.
Posted: Fri Jan 10, 2014 6:31 pm
by soullad
prefer the early Li 125 engines myself, original gearbox with 18 x 47 allows a quality new 82 link chain, gives a great ratio for a torquey motor, nice 1st gear for loaded up scoot / clutch life etc plus most have had an easy home life and then subsequently been left alone by the Island Ape boys.
Dread to think what Mikes list would total up in retail value ?
