Lambretta Flywheel Timing Marks
Posted: Fri Jan 03, 2014 10:19 pm
Marked TDC on casing (positive stop method) then set the flywheel to 17 Degrees. Using the the 2 window marks the stator was then lined up. A problem with the scooter then led us to fit a 2nd flywheel........lining up the flywheel at 17 degree it was noticed that the stator was about 10 - 15 degree out compared to the first flywheel.
I presume the 2nd flywheel should have been a straight forward fit with no adjustment needed on the stator ?
We decided to strobe the flywheel to check but didn't. If the window marks were incorrect what is to say the firing mark on the flywheel was ok, if it wasn't how would we know ?
So the question is......If a flywheel had no marks on it at all is it possible to set up and check the timing or if it has how do we check that is correct ?
I'm thinking the problem is establishing a true firing mark on the flywheel.......i suppose the answer isn't limited to Lambrettas but to all flywheels with firing marks.
