BGM rear LED unit
Posted: Thu Jan 02, 2014 10:03 pm
by Jxmiddle
I've just fitted this to my 66 SX and it works a treat. Just wondered if anyone else had problems with fitting. The unit seems small enough to sit within the lens and so when you screw the lens in it doesn't hold the unit against the frame. The first time I did it the unit fell forward and ended up at an angle inside the lens. I eventually used some sealant to hold it in place but I worry that vibration will end up shaking it loose. Anyone else had this experience and found a solution?
Thanks
John
Re: BGM rear LED unit
Posted: Thu Jan 02, 2014 11:37 pm
by Timbo
Silicone was recommended when I fitted mine, not moved at all...
Posted: Fri Jan 03, 2014 12:29 am
by rosscla
I got a similar unit on my GP, I just drilled thru it and attached with a couple of self tappers and passed the wires thru the original bulb holder hole
Posted: Fri Jan 03, 2014 7:15 pm
by Mike - - Bristol
2 questions if you help guys.
Are they nice and bright , I tried an early LED bulb before and it was crap.
Are the LED's white or red ?
Thanks.
Posted: Fri Jan 03, 2014 8:16 pm
by Toddy
Mike - - Bristol wrote:2 questions if you help guys.
Thanks.
Mike
Very good and white LED's
Posted: Fri Jan 03, 2014 8:53 pm
by Mike - - Bristol
Thanks Toddy just re-read my post and even I struggled to understand the broken English ! Must check my typing in the future !
Thanks for the reply, one of the lads on the Bristol Lambretta club said his was red and I thought that was a little odd.
Posted: Fri Jan 03, 2014 8:58 pm
by Timbo
It looks red when it's all fitted.. :roll: ......... :lol:
Posted: Fri Jan 03, 2014 9:10 pm
by Mike - - Bristol
:roll: Thanks
Posted: Fri Jan 03, 2014 9:37 pm
by rosscla
Here's what it looks like on mine
And on the bike in daylight
