Fork Spring Compressor
Posted: Mon Dec 30, 2013 6:04 pm
by nellyboyo
I need to get one of these for the shed so .....are they all much the same or are there types to be avoided ?
They do seem to vary a fair bit in price ....cheers
Re: Fork Spring Compressor
Posted: Mon Dec 30, 2013 6:14 pm
by nelson pk
Get a good pair that have the bits that screw in where the fork link bolts go. I bought a cheap one that just had holes in where the bits that screw in should be. Ended up tapping those holes and putting my own screws in. For the extra ten or fifteen quid i wish i'd have bought a better quality one from the start.
Posted: Mon Dec 30, 2013 6:32 pm
by soulsurfer
nelson pk wrote:Get a good pair that have the bits that screw in where the fork link bolts go. I bought a cheap one that just had holes in where the bits that screw in should be. Ended up tapping those holes and putting my own screws in. For the extra ten or fifteen quid i wish i'd have bought a better quality one from the start.
Exactly the same for me, although a large ring spanner can be quite effective ;)
Posted: Mon Dec 30, 2013 6:43 pm
by nellyboyo
Which I have many many of ......can you describe how you use one to to this .....free huge AF ring spanner to a the first pic that makes sense to me ....trust me I`ve got loads .... :D
Posted: Mon Dec 30, 2013 6:57 pm
by nelson pk
If you have stickies book its in there. Once you have your fork link in and your forks upside in a vice you can get the ring part of the spanner in the link where it would attach to the hub and pull down on the spanner to give you room to put the bottom buffer in. Beware that if you use uprated springs it will require all your strength! I nearly broke my wooden bench that the vice is held on to when i done mine :oops:
Posted: Mon Dec 30, 2013 10:18 pm
by jazzyb
Got mine from scooter restorations no probs does the job every time 8-)
Posted: Tue Dec 31, 2013 7:58 am
by nellyboyo
Cheers all for the advice , :)
