piston ring peg
Posted: Mon Dec 30, 2013 3:56 pm
by Tosh
just rebuilding a mates scooter gp200 engine and noticed that the top ring pin is no were near out as far as the bottom ring pin.
what options do I have ? new hole put in,Or a new pin put in, Its just a std indian top end.
Ta Paul
Re: piston ring peg
Posted: Tue Dec 31, 2013 11:28 am
by tavspeed
might be the the top one is good,and the bottom is coming loose,is it the original piston or a new one.
Re: piston ring peg
Posted: Tue Dec 31, 2013 4:03 pm
by Eibar
Get yourself to "Grampian Engineering" to get it re pinned (not too far away from you)
Re: piston ring peg
Posted: Tue Dec 31, 2013 4:06 pm
by Eibar
just re read your post and noticed its an indian top end so I assume its a cheapo piston and re pin may outweigh just buying a replacement unit
Re: piston ring peg
Posted: Tue Dec 31, 2013 7:39 pm
by Tosh
thanks for the replys,as for assuming a cheap piston which is prob correct but I`ve had the same troubles with a peg coming out of an asso piston and messing up my top end up after it had been sorted to 14.65bhp..
and also it is the original piston
